RB22 built - Introduction
NathanBrazil
Car: 1991 S13 Hatch RB2XDET - CP Piston, Spool Rods, HKS HG, GT3076R - Nistune
1993 Welded-diff stock a** E36 325i
Hello guys! I'm new to the forum.
My name is Nathan and I live in Orlando, FL. I used to be a Professional Go-Kart driver in Brazil. Sorry for any English mistakes :gapteeth:
I own a 1991 S13 Hatch, witch I swapped a RB20DET SilverTop.
This thread is a close guide to my RB22 build. I hope this could help people by providing information, pics and I'm always happy to answer questions.
First of all, I want to post a pic of my car, and how the engine was when it was 100% stock. Here it goes:
After I had fun with around 200whp stock everything, I decided to add some bolt-ons. Thinking big, I got a GT3582r, 800cc Injectors, Z32 MAF, Top-Mount exhaust, eBay Plennum and Nistune ECU. I made 326whp and 240ftlbs @21 psi. Couldn't go any higher due to my weak wastegate spring. I was still able to break my tires loose in 3rd gear! :crazy:
Everything was awesome until one day, cruising down on the highway, my stock coolant temp gauge quit working and I only realized when it was too late. I was only running with one fan, it was a hot night and I was pushing it :yesnod Then, it overheated :mad: :cry:
My lifters started to tick and it was spiting metal shaving from PCV breather. A week later, It blew the head gasket :frown:
Good with that, I installed a new OEM head gasket, took cams out and looked up for any more broken parts, but everything seemed good, but for my cyl #2 that fried when it overheated. All cyl have around 151psi of compression, cyl #2 has only 89psi :rolleyes:
Thats when I decided to build a RB22 instead of going RB26. One of the reasons is the cool factor and how the RB20 sounds...Yes, it sounds amazing to my ears :)
My car now runs like crap and only on 5 cylinders. I'm not worried about it because I just got a RB20 Block to start my build :naughty:
I'm taking it to Raw Brokerage to have it machined and to buy all parts needed. My plans are 82mm Custom CP Pistons 9,5:1 cr, Spool Rods, HKS 1,8mm 3-layer Headgasket, extended crank collar and lots more. By the end of this week I'll be posting more pics of the process, since disassembling the engine to its day of debut. Might take a while but I will get it done.
I really hope this thread helps people who ever wanted to build a RB22 but never had a way to start or even found information about this build.
Thanks for reading and again, sorry for any English mistakes!
gnubberlang
Car: 1995 240SX SR20DET
2004 Frontier 4x4 Crew Cab 5-Speed
Looks nice man. Good luck. I saw those RB20 intake manifolds on ebay, did yours give you any problems?
NathanBrazil
Thanks bro! And I never had any issues! Just need to buy the fitting for the vacuum ports and for the Brake Booster vacuum line, not that big of a deal. I got it mostly to remove my inter-cooler piping from the front of the engine.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Nice build, I'm running a SC61 (laggy) on my 20. Made 415whp @ 18psi on pump and 430whp @ 18psi with meth injection and more timing.
NathanBrazil
So, I'm finally back!
Sorry for taking too long. Had to deal with some issues here and there. :eek:
Good thing is, build is coming along! :naughty:
Here she is! Ready for Blueprinting! I'll come up with some useful info as much as I can. :biggrin:
Crankshaft got the larger Oil Pump Collar installed! Soon I'll post pics from Before/After so you guys can clearly see the difference! :chuckle:
Thanks and be back with more info!
Cheers!
Yellow4g63
Good deal at least you have the ball rolling.
