mca1990 wrote:hey, im also having trouble finding the fourteen pin connector. where is it hidden?
as stated just before me, it can be found in the driver's side kick panel on a stock 240sx (all cases, I assume???), but if you have a motor swap, then it will probably be on the wiring harness about 10 inches away from the swapped ecu (??)
Here is my other thread that I wrote after this one, once I finally got finished.
zerothread/314850
I never got back to figuring out why datascan wouldn't connect when that plug behind the glovebox was plugged in, but I am pretty sure now that it was because of a loose ground on the cable, so ignore that part...lol
I think there is a pic of the 14pin connector on the link above also...
--TJ
