rb20det wontfire/cough, only turnover
manlove891
maybe my replacement ecu is no good? any idea how i can make sure ecu is functioning without another rb20? im the only one with another rb20 in my area and its in my living room so no chance of testing it on that
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
I'm out of ideas, old son. You'd think it would at least backfire. Short of timing the signals out with an oscilloscope, I can't think of any way to test the ECU.
VStar650CL
Technical Expert
I dunno what the guts of an RB20 CAS are supposed to look like. Is it possible it's 180 out?
manlove891
anyone on the forums you might know that can help? this is where we are.
fuel- y
spark- y
ecu code- 55
zero combustion what so ever.
engine was running when parked then it flooded.
theoretically it should only be electrical problems.
ecu was replaced and is working however i do not know if it is functioning correctly as i have fuel spark and timing done.
manlove891
going to do a compression test before the day is out just to rule out compression loss as a factor. do i need a leakdown test for valves or will valves be included in the compression?
VStar650CL
Technical Expert
You only need a leakdown test (or a wet test) to isolate the cause of a compression loss. If they read healthy on a standard dry cranking test then usually nothing more is needed.
manlove891
so i was messing around with the timing. gas pedal pressed all the way after like crank 6 it started to sputter but it did not start, atleast i have some sign of life. maybe i just need to go over timing in depth and just let it crank on a full charge with the pedal to the floor
