rb20det wont start!
crxcess
Car: 93 240sx fastback
Well I got the motor in ok, everything is plugged in.I got spark, and fuel pressure. it just wont start. also im having to start the car by taking the starter wire (black/white). when i plug it in to the other wire its wanting to start without the key. I followed the 8 step to starting an rb motor but no go!:confused:
crxcess
never mind! I got it going! I had the fuel lines reversed!
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Haha knew it.
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
Ha..ha.. I did the same thing on my swap, took me 3 hours to figure it out :)
93RPS13
Car: Cars, Girls, Cars, Food
Nice more pics??? so the wiring writeup is good right? any sugguests for wiring also is it the first time you wired an engine?
BoostFab
Car: S13cp, S13fb, S14z
that sounds very exciting. so the 8-steps did work for the rb20!
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
WORKED FOR ME, BUT I MADE A FEW ALTERATIONS AND UPDATES.
crxcess
Yes its the first time I wired a nissan engine... I have done hondas before. Everything worked fine, I had a few questions. one was step 7) what white wire? answer: 8 gauge wire( real thick one inside of the loom) . I am also having problems with the starter wires, I think its because my car was an automatic. problem is I cant connect the wire because it activates the starter without ignition key input. It could also be because I didnt use the Ka positive battery harness. Branden (wiring write up author)was a Big help! Also you have to hook up the piping or it wont start!
crxcess
here is another pic
dekand
Car: 1995 240sx SE
sweet man :)
93RPS13
PROJECTRB240SX wrote:WORKED FOR ME, BUT I MADE A FEW ALTERATIONS AND UPDATES.
please share???
PROJECTRB240SX
I JUST USED THE KA LOWER HARNESS AND SPLICED THE RB PLUGS ONTO IT. THERE WERE A FEW OTHER THINGS THAT I CAN'T THINK OF OFF THE TOP OF MY HEAD.
ONE THING IS IF YOU DON'T HAVE THE MAF HOOKED UP IT WILL NOT START AND IDLE.
Joe
crxcess wrote:never mind! I got it going! I had the fuel lines reversed!
hahahaha i cant count how many times ive heard that when helping someone with a nissan swap
good job :D
frosted flakes
that was our same problem! lol fuel lines reversed
rudeboy
Car: cars
i do it on ka motors aslo.nissans fuel in/return lines look madd backwards on the intake
crxcess
Got a question?My car was an automatic... if I jumper the auto trans wires I can use the key to start the car? I retained the rb trans harness, only thing I kept was the speed sensor. I have read that I need to jumper the wires on the transmission harness? Is it possible to just jumper the wires in the console area where the shifter is? If so then which ones?
