rb20det won't run now need help!!!
justinbarley
Car: 1992 240sx with a rb20det
I just bought a 1992 240sx with a rb20det in it. On the way home from buying it the radiator poped. It was running after i put the new one in. Then the cas shaft snapped i got a new one. It was out of a j30 i had read on here that it would work on the rb. Put it on and it will not start or even back fire. The motor has been completly retimed and everything set at TDC. I dont knows goin i have checked spark and fuel im at a lose. So any help will be much appreciated! I'm in Arkansas
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
You prob need to repin the plug to make it work. Look up the diagram for the J30 CAS and the RB20 CAS and repin to match.
justinbarley
I have tried to find something to show me how to take the j30 apart so I could and I can't find anything
themadscientist
Check to make sure the drive gear in the exhaust cam didn't break off. I bet it has.
Yellow4g63
Justin your going to have to do it the hard way. Find a FSM for the Z32 since I'm sure the J30 uses the same CAS and find the FSM for the R32 and look up the wiring to see which pin is what on both. Then rewire the plug to match the Z32. I would prob search the s*** out of google 1st tho lol.
justinbarley
The shaft is still good
justinbarley
Yellow4g63 wrote:Justin your going to have to do it the hard way. Find a FSM for the Z32 since I'm sure the J30 uses the same CAS and find the FSM for the R32 and look up the wiring to see which pin is what on both. Then rewire the plug to match the Z32. I would prob search the s*** out of google 1st tho lol.
What's the Z32 and a FSM? I'm new to all this so I'm not sure what that means
Yellow4g63
Z32 = 300zx the 90's one. FSM = Factory Service Manual. You can find them online in PDF format.
justinbarley
Ok so I changed out the shaft on the original cas got it lined up and only got it to hickup and that's it. Still at a lose on it
ANVIL
Car: RB25DET S13.5
Get an rb20 one
justinbarley
That's what I have its the rb20 cas with a new shaft
Yellow4g63
Ohhh I was confused, I thought you said you were running a J30 CAS on your RB20. You can test the CAS by just spining it with your hand and see if you hear the injectors click and pull a coil pack with a spark plug and lay it on the valve cover and watch to see if it's arcing. That will let you know what your missing, fuel or spark. The RB20 uses two relays for fuel and spark, at that point you might want to check to make sure they are getting power which ever one isn't working.
justinbarley
Where would the relays be at? And I have spark I'm thinking it's a fuel problem
Yellow4g63
they are by the ecu 2 green relays.
justinbarley
Real quick questionwhat kind of code reader do I need to be able to pull codes off the rb20det
Yellow4g63
If it's wired to the cluster you won't need any or if the led on the ecu isn't fubared. it flashes the numbers on the check engine code. slow flashes are the 1st number and the fast flashes are the 2nd number. If you see it flash 5 slow then 3 fast that's 53. Then u look up code 53 online.
justinbarley
Ok so when I look at the led light its just solid red what's that mean?
Yellow4g63
justinbarley
Would any one have A series 2 rb20det cash?
justinbarley
Cas
justinbarley
Ok so come to find out my injectors aren't spraying fuel into the motor is there any injectors that I could get from auto zone from a different car that can be used on the rb20det
Yellow4g63
the top feed KA injectors. from the single cam I think were the same size as stock.
justinbarley
Here is my question I'm getting the all clear code from the ecu but still not starting up. The cas is in the right spot. Plugs are sparking when I had pulled them out to check them. But even with starting fluid put into the intake I can't get anything. I'm at a loss
Yellow4g63
So your getting spark but no fuel? Do you have the 2 green relays in place? they are really close to the ECU.
justinbarley
Both relays are good. You can feel them both click on then off when you turn the key on and off. But even with starting fluid sprayed down the intake I don't get anything
Yellow4g63
try reversing the fuel lines at the rail if the injectors are not spraying.
Yellow4g63
btw did you take the CAS off and spin it by hand with the key on to see the injectors spray and the coils fire?
