underground »
https://forums.nicoclub.com/underground-u11170.html
Sat Aug 14, 2004 12:38 pm
Christian, I really do think it's overboosting. This would make sense as the hose off the FMIC blow off. In addition, you mentioned the wastegate was stuck open. All of these things make me think that the overboosting is causing your knock sensor to trigger the ECU.
While I don't know why the ECU is not reading, that may never be determined.
I figure that when it trips the ECU, the ECU pulls timing, and sets maximum RPM to the 5500 Range (Default perhaps)
This would also make sense of why when you are in neutral you can rev all the way to redline.
When the motor boosts over 5500 RPM, I figure it is also probably leaning out the injectors and probably causing detonation as well.
I dont know, but after reviewing your problems, this is what I am thinking.
We really need to find that boost gauge. Surely, somebody in AZ would be gracious enough to part with one for a price.
Chris
