The f3 plug from the s14 was tied into the harness and was not sodered or taped up or anything. so i decieded to un tape the wiring further where the harness would be in the engine bay area and noticed more wires cut and needed help figuring out what the plugs are and what the wires got to.
Plugs:
what does the black wire on this plug go to? it reads nissan 0.47 uF
on this plug the black wire is loose also....i kno the top plug is for the ignitor..
and also i kno the write ups and harness ive done b4 have a blk/pnk stripe fuel pump wire.. on this harness its dont seem to be that color its red/wht stripe. ive looked at several ecu pinouts and ive only seen blk/pnk stripe is that common?
