Carl H »
https://forums.nicoclub.com/carl-h-u9196.html
Tue Aug 15, 2006 4:03 pm
yup, you can remove all the wires except the brown wire that gets 12v when switched to 'on', you'll need to run a wire from the inside of the car to that wire for o2 sensor heater power, but the rest you can pull out.make sure it runs first tho, dont want to have to redo the wiring...once you get that far i can shoot you in the directionfor the interior bits.
