RustspecS13 »
https://forums.nicoclub.com/rustspecs13-u75597.html
Wed May 13, 2009 6:42 pm
Are you getting any kind of popping in the exhaust or intake like its firing but out of order?
If you set the engine to TDC on the compression stroke, and look at the timing belt, you should have 47 or so teeth from the mark on the crank shaft to the exhaust cam dot, then like 32 or so teeth to the mark on the other cam. I have it written down some where, or you can find it in the skyline R32 FSM.
Sounds like your closer then my swap, you just have to make sure everything is spinning exactly when it should.
~Alex
