rb20det vs l28et
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
kelloggman
Car: 73 240z
ok so i wanna swap my original l24 with either rb20 or l28if u could give cost ranges and other useful info would be appreciated i am completely new to this and im doing researchif you could help much thanks
Modified by kelloggman at 1:10 AM 5/14/2009
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
well, for the L28ET swap, you can locate a wrecked donor for around $500 take everythign you need and sell of enough parts to py for the parts car, at least this is how I've done ti 3 times, the engine bolts directly in place and even bolts to your transmission, however if you luck out and find a 5 speeed sturbo parts car then even better
the RB20 has less displacement so you's have to work harder to make the same power (yes the RB is mroe efficient but more displacement = mroe power) you then need to by the motor and trans moutn kit form mckiney or fab your own, and have a custome driveshaft made
mikeith
Car: 73 240z
i agree. you could do ALOT with a l28et and for an extremely reasonable price! IMO its one of the easier/cheaper turbo motors to build.
raremotive
Car: 04 Infiniti G35
evildky wrote:well, for the L28ET swap, you can locate a wrecked donor for around $500 take everythign you need and sell of enough parts to py for the parts car, at least this is how I've done ti 3 times, the engine bolts directly in place and even bolts to your transmission, however if you luck out and find a 5 speeed sturbo parts car then even better
kelloggman
Car: 73 240z
cool. how much hp can one get with a l28et stock and how much with upgraded items
NSR_s30
Car: '99 Ford F250 7.3L Diesel
'71 Datsun 240Z
L28ET is the way to go, it's the way I'm gonna go. I have a L28ET and 5spd lined up. Just have to start collecting parts. The the motor stock I think you can get a decent amount out of it. Theres videos of guys on youtube running just upgraded turbos and upgraded fuel systems 300hp +....so it all depends on how much money you're willing to spend.
evildky
06 Nissan 350Z GT
kelloggman wrote:cool. how much hp can one get with a l28et stock and how much with upgraded items
stick turbo injectors and management max out around 230 whp, HG and headbolts max otu around 30 whp, and the stock internals max otu around 400 whp, the block, crank and rods are good to north of 600 whp
kelloggman
Car: 73 240z
thanks guys for all your input and adviseim really excited to start this uphahah need to save up again but that is the easy part
blackice280zx
Car: 280zx 1981 x2 1999 volvo v70
l28
Rare_f8 wrote:
l28 for the win easy and cheap plus I just love the l28 motor
TAcroc
l28ftw...tired of all the nissans with the rb in it...not that i hate it but i love seeing something different
Leash
Car: '76 Datsun 280z, '99 Honda CRV AWD
I've sat in one with an RB, same with the L28. I prefer the L28 more.
My boyfriend wants to swap it out for an RB, but thats not happening while I'm around
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
L28 is the way to go. it's easier to get more hp out of the rb, but it dosent feel right in a Z. I'm looking for a 5 speed stick from a l28, any givers?
evildky
06 Nissan 350Z GT
flinterman2000 wrote:L28 is the way to go. it's easier to get more hp out of the rb, but it dosent feel right in a Z. I'm looking for a 5 speed stick from a l28, any givers?
no, actually it's easier to get more power form the L28ET, it has mor edisplacement and a larger turbo, the RB20ET turbo will max out around 200-250 whp max, the turbo ont he L28ET si good to north of 300 whp
ravera
Car: 1971 Datsun 240Z
as far as the L28ET goes, the bottom end is pretty rock solid, and to be honest you'll start burning through transmission's LONG before you have to put substantial money in the motor. IIRC, if you start to kick more than about 350WHP to the rollers (super easy with that motor), you'll even start to eat the T-5's that came in the 280ZXT.
Bob
Red-rbz
Car: 260z n 280z
Iwill choose rb20 over l28 anyday. It just that rb20 is more realible and faster respond.
evildky
06 Nissan 350Z GT
Red-rbz wrote:Iwill choose rb20 over l28 anyday. It just that rb20 is more realible and faster respond.
someone doesn't know how to tune an afm
Bleach
Car: Three Z-cars
evildky wrote:someone doesn't know how to tune an afm
As someone who owns a Z31 and Z32 turbo you should know the electronics in those cars are vastly superior to the factory 280ZX AFM system. I'm surprised you haven't put a Z31 ECU in your 240Z actually.
evildky
06 Nissan 350Z GT
Bleach wrote:As someone who owns a Z31 and Z32 turbo you should know the electronics in those cars are vastly superior to the factory 280ZX AFM system. I'm surprised you haven't put a Z31 ECU in your 240Z actually.
the Z31 ecu si much better , the stock eectronic's on the L28 suck, but can b
effective my 240Z and my Z31 both run megasquirt, which is far superior to the z31 electronic's
kelloggman
Car: 73 240z
which is bettermegasquirt or jwt
ravera
I have no experience with JWT, but I will have to say there are many, many Z owners running megasquirt and it's VERY tunable. In my experience with it, I'm quite a fan, and can easily be changed on the fly. The JWT may be a little easier to get running since it's a re-prommed factory ECU but the MS has much more tunability.
evildky
06 Nissan 350Z GT
I don't think thats a fair comparison, megasquirt is fuly programable, JWT are jus tuned chips taht are stil quite conservetive as they are talyored to work safely for the masses, nistune of similar woudl be a mroe accureate comparison, it really just depends on what you are more comfortable tuning with
HowlerMonkey
Car: 1991 Infiniti M30 wi/ L28ET
M30 ecu is sequential and it runs fine on my L28et with the 259cc turbo injectors with zero tuning.....just dropping resistors.
Then you have to find one though it is possible the single cam maxima and pathfinder ecus made after 1990 might be sequential as well....haven't looked into it.
I really think the later VG30 OBDII ecus will end up being the way to go once someone spends some time finding out which addresses contain the values you want to tweek on the .bin file.
Then you can just load it through the obdII port with a multitude of programmers from the vetronix master tech, to the blue streak iFlash unit, to the Global Programmer.....etc.....the list goes on.
Of course.....you will need to add a sensor that "listens" to the ring gear in order to not have a check engine light or if you want full self diagnostic capabilities.
Return to “Datsun Z Forum”
