rb20det urgent help wiring.. no spark
Baggedrb20
Car: Bagged ford courier 1988 with rb20det
hi guys, i have been wireing up my rb20det into my 88 ford courier, i have followed this website http://forums.hybridz.org/topic/90784-w ... -datsun-z/ to help me along with wiring it in, as showen i have wired the two constant power wires and the ign wire then the other wires that needed wiring then it says to test it. I have done this, Starter motor works, alternator works, have ecu power (red check light comes on, but stays on even when keys out of ignition?) but i dont have spark!, it is grounded, have tested spark plug on coil even changed ignitor but still nothing. Is there a wire that i am missing or something that could be missing? any help will be very helpful! thanks James
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Do you have power at the two green relays near the ecu?
