Rb20det turbo gasket question
gbaz77
Car: 240sx
hey guys,
ive been told i probably have a spent turbo gasket. my car makes a whistle (not the turbo whistle) that sounds sort of like a mix between a whistle and a child's impression of a machine gun. its like a pulsating whistle and sounds alot like a blow by from a spent gasket.
my question is, would it most likely be the t2 gasket below....
or this gasket....
and i guess my next question would be should i just change both??
mello88
Car: s13
It's a T3 gasket not T2. You have to pull the turbo off to replace it, so you might as well do the other one while you're there. You may wish to replace the banjo bolt copper washer too.
gbaz77
Car: 240sx
rb20det is t3?
Sil240
Car: Nissan S13 "The One Cam Wonder"
Yes, T3 FlangeChange both
Chaos the Xile
Car: 1974 Datsun 260Z
well hell if you are pulling off the turbo upgrade to a RB25 turbo...
gbaz77
Car: 240sx
yeah, im planning to upgrade to a bigger turbo. i'll fill you guys in when i do. im still saving, just trying to plan accordingly. thanks for the info.
