Cjmartz2k »
https://forums.nicoclub.com/cjmartz2k-u65761.html
Mon Oct 12, 2009 9:56 pm
A SAFC would probably work in your situation. Not the best solution, but better than nothing. It lies to the ecu telling it there is a different amount of air going through the MAF than there actually is. This just pushes the ecu into a different part of the timing/injection maps (both of them). You can get the fuel right, but the timing will be off a bit. How much is determined by how much fuel you take out.
I don't know about "mail off" tunes, I was just talking about ROM tuning your ecu. I used to drive for my shop guy who did it on the fly back in Oki. You for a stock turbined car though, most everything is pretty standard, so if you tell the tuner what you have, he tunes it from experience and mails it back to you, you could then get an SAFC and tweak it. Hopefully it wouldn't need much tweaking, but yes, you'll need a wideband and of course a SAFC. By that time you could have bought a stand alone.
I think with a stock turbine though, a mailed ROM tune from somebody who it known to do it is a good idea, and the most cost effective. Or you could find somebody you are willing to drive to, that would be optimal.
