RustspecS13 wrote:The RB25 and 5 speed rb26's are essentially z32 and 86.5+ z31 turbo transmsissions. The pathfinder might also be the same, but it uses different gearing, and you dont want to run that gearing. Same with the different front and rear housings though.
~Alex
From what ive read, the pathfinder statement is true, but the pathfinder's 1st and 2nd gear are too short to be usefull in cars like ours. if you could swap 1st and 2nd gear you should be good though... but again this for the RB25 and 5spd RB26 trannies, not the RB20,so sorry OP i got nothin
