LSDrift »
https://forums.nicoclub.com/lsdrift-u39769.html
Wed Aug 17, 2011 10:27 am
bigfootap, did you ever get this problem figured out? I've got the same issue at the moment. It's not causing me any problems shifting or anything but it's kind of an annoying noise...
Also, when I barely put my foot on the pedal, I get a light squeal that sounds similar to squeaky brakes but not so high pitched. You get any of that? I put in a SPEC stage 2 clutch/pressure plate, new T/O bearing and bushing, and resurfaced the flywheel.
