Kamin wrote:no it wontthe RB20 trans uses the the SR/KA transmission internals, the RB25 uses the 300ZX internals.
you at the very minimum need a RB20 transmission bellhousing then you can use internals from a KA. but the KA trans will NOT bolt onto the RB20.
so i never really found a YES or NO to these questions.
can you use the KA internals, inside an RB20 transmission?
if the RB20 uses the same as the KA internals, then it shouldn't be a problem getting an RB20 transmission rebuilt by a transmission shop in the USA?
