Rb20det TPS Volt specs?
blues14
Car: 1995 Nissan 240SX GTS-t
I am having a problem with my rb20det in my s14 with highend power. the motor stops pulling at 5,000 rpm. I was wondering if anybody knows what the TPS needs to be set at . I tested voltage and it read .51 closed and 4.19 at WOT. Does that sound about right? Its really sad when your rb20 powered s14 can barely pull from a basically stock Del Sol Si (my bros car) I am looking at everything I can to fix this problem.
tight240
For tps sensors their usually in that range of operation, frome the information i get off here, somebody is probably going to tell you to check for a boost leak, or a vacuum leak
goofynick6
Car: 1995 S14.5 RB20DET
TPS sounds just fine..
blues14
can somebody test theirs if they find the time? I know the ka24e tps is supposed to read .40 closed and 5.00 at wot. you connect at the white wire(think its the middle) on the connecter under the tps that (of course) goes to it. test it with ignition hot, but not running. Thanks guys
goofynick6
I already said the tps was fine. I have the skyline RB20DET manual and have done extensive research on the tps function..
