Carl H »
https://forums.nicoclub.com/carl-h-u9196.html
Sat Aug 22, 2009 2:02 pm
q45 is not a direct bolt on, while it will bolt on and function properly the idle switch will need to be rewired to use the q45 plug...i have not found a usdm counterpart for the rb20 tps yet.I do however use a q45 tps with q45 idle switch on it and it works just fine...
