RB20DET ticking/boost leak?
0range_240
Car: 89 HCR32
Just before I parked my car for the winter last year, I noticed it had developed a hollow ticking/sucking sound past 4k or so when I was stepping on it. It does not seem to be RPM-related, it seems to revolve around heat. I only seem to notice it when its hot outside (30c) and its not consistent. Now that I have the car back on the road again its still making the same noise. Whenever it starts ticking like that under acceleration, I get a slight boost in power it seems, and as soon as it stops I can feel it lose some power. It almost sounds like a wire grounding out on metal or something, but I checked all around the engine bay and I couldnt find any frayed wires. The car doesnt sputter or run rich, it idles nicely at 900 rpm, its just up top.
I replaced the fuel filter, air filter, and removed my old crappy manual boost controller. After i did all that it went away for a couple weeks and it just came back today.
I did a search already, but no one seemed to have a problem quite like this one. I am going to check under the heat shield for lose nuts on the manifold once ive let the engine cool off a bit, any other suggestions?
Im quite stumped.
oh and btw, so far my only mods are Intake/exhaust/GT-R clutch, besides that im stock. The engine is also fresh, it was installed at autodream. Interestingly enough this ticking noise was present with the old engine aswell.
PS: my apologies for the long post, but I figured the more details I could give the better
0range_240
Car: 89 HCR32
Checked the manifold and it all looked good, I noticed its worse in the highers gears, when im in between 4.5-5.5k for a longer period.
Im totally stumped, maybe a leaking wastegate?
TTT
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Did you check the altnator? maybe it's lose or maybe hmm I don't know lol. I never had that problem.
0range_240
Car: 89 HCR32
I changed the plugs and it runs smoother now but the noise still seems to be there, it only seems to be present between 4.5-5.5k or so, before and after is fine. I'm going to go through all my piping tomorrow and try and look for a boost leak?
the only other thing I can think of right now is possibly the fuel pump?
btw, does anyone use MSN or AOL that doesnt mind tech talk? None of my friend's know a terrible amount about forced induction or anything like that.
rbspitfire
its not detonation is it? maybe youre loss of power occuring when it stops is the knoxk sensors pulling lots of timing out?? just a quick thought
0range_240
Car: 89 HCR32
if it was detonation, what would be causing it? and what exactly does detonation sound like, because this is not very audible
