rb20det throw out bearing
nateb
Car: s13 hatch *working progress*
anyone know if any other motor bearing works?
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
should be the same as the KA, not sure though.
Search "replacement" under the RB forums and you'll find the interchangable parts for these engines.
nateb
hmmm... looked around couldnt find anything exact...can i use a rb25 T/O bearing in a rb20?? or how about a NA z32 t/o?? or most simply anyone know where to buy one?i was lookin at clutches and i noticed that they say the clutche work for rb20 and rb25 and it comes with a T/O bearing
nateb
i think i found my answer.....rb20 uses z31 throw out bearingand rb25 uses z32 ill post on that other thread cause it wasnt there
uber95
Car: S14
Where did you find the info? The RB20 uses a Z32 clutch, not a Z31 so that may be wrong info. Can you find pictures and dimensions to compare?
