so i recently got an rb20det swapped s13 coupe. been reading a lot up about them, and having some problems with no luck.
first, it started with what i think/hope to be a boost leak. motor pulls fine til about 4k-4500k then it makes a screaming sound. horribly loud. well i read up that a common boost leak spot is the seal behind the tps going bad causing it to leak. and that that particular seal cannot be replaced and a new throttle body is in order. in the process the bottom bolt holding the tps broke. well the head of the screw.
now, i also read that ka24 tb's are the same size and should work. is this correct? if so it would be a lot easier to get ahold of a ka tb rather than a stock rb tb. can anyone help with this? thanks in advance
