RB20DET tachometer problem
Benz_200t
Car: Mercedes Benz W123
Hi guys....i have an old W123 benz with a RB20DET in the engine bay.....
recently i just had done some wiring to the car.....and accidentally snapped the tachometer wire signal to the meter.
after i connect it back, the tach goes weird...
when the engine is not running, the tach will be at 0
if the engine is running, the tach is pointing to 3000rpm....
i have traced the wire directly to the ecu pin no7...thats the rpm signal pin..
for your information, i am using a A31 meter.
i dont know what is the problem...
found some info in SAU and SDU websites....and i have not found any cure for my problem....
i am very stressed with this problem...it has been a month now trying to settle this problem on my own.....
i really hope that u guys could help me.
of at least do teach me on how does the ignition signal worked on the RB20DET engine thus giving signal to the tach.
Maybe from there i have some ideas on how to solve this problem.
thanks alot in advance......
fast_s13
make sure you dont have a short in the wire
Benz_200t
i have checked for any type of shortage.....
even,i have done a new wiring for the rpm meter....
