RB20DET
Lonismos14
Car: 1995 Nissan 240sx, 1999 Chevy Hoe, 1996 Saturn Sl2
Hey guys i read the fsm, but did not see the torque specifications for the clutch and flywheel. How many foot pounds thanx. :biggrin: Or if i just hit it with an air impact will i be ok. :cool:
okidrift88
Car: 1995 240sx se with sr20det apexi headers apexi airflow converter, g-reddy front mount, blitz blow off valve, aftermarket radiator, electric cooling fans
staright pipe exhaust, 2 ways lsd
im pretty sure that that u dont need to tourque down the flyweel but the cluth needs to be tourqed. what u should do is download the repair manual online and it has all the specs in it
RustspecS13
Car: '74 260z and '88 300zx turbo
The flywheel is in the 90-110 range and the clutch is 20 or 30ft-lbs I believe. It has to be in the FSM- you just have to look for it some times it can be a PITA.
~Alex
Joe
i promise, its in the FSM.
julio
Car: RB26 AWD converted S14
okidrift88 wrote:im pretty sure that that u dont need to tourque down the flyweel but the cluth needs to be tourqed. what u should do is download the repair manual online and it has all the specs in it
Yea, no need to torque down the flywheel, just put them in finger tight and call it a day lol.
