Snakeyes39 »
https://forums.nicoclub.com/snakeyes39-u7382.html
Sun Jun 29, 2003 6:14 am
i'm just finishing up my swap right now, the only thing u have to do different is either buy custom motor mounts or go with a R32, A31 cefiro, or R33 laurel crossmember.
i went the crossmember route cuz i thought i'd be saving a bunch of money doing that, but it kinda bit me in the a$$. basically my engine sits a bit too high for the original hood, i even put 4mm worth of spacers to drop the crossmember alittle. i read a thread on some aussie site that they lowered the crossmember 10mm to clear the hood, but with the equipment i had, i don't see that as being possible.
so right now i'm still looking for a hood that will fit my car, i'm probably gonna end up having to get a fiberglass hood with some kind of scoop and then have someone fabricate that to fit.
as far as interchangeable parts, i'm pretty sure basic things will work. exhaust side of the 20 and 25 are basically identical but the intake is different. u can also throw some 26 parts in pretty easily, i'm using a triple plate GT-R clutch, fuel pump and also got some fuel injectors off a GT-R i'm about to have put in.
oh, and another special note: if the engine u originally have in your 240 is a single cam KA (like mine was) u're going to have to grab some new powersteering lines if u plan on keeping the powersteernig. i'm using the lines out of a '95 twin cam KA and i'm still kind of in the process of making it work, not sure what the problem is, but i'm pretty sure it's just for my car and not everyone elses, i may have bent a line.....
hope this helps u out in some way...
