rb20det swap no spark
gandza
Car: s13 240sx rb20det
okay, so i just swapped an rb20det into my s13 and i have no spark, i have constant power to my coil, i have continuity from my ecu to my ignitor, BUT i olny recive 1 volt to my ignitor, and i cant figure out why? and all of my grounds are hooked up, i even made a couple extra engine grounds, everything is hooked up and my cas is making the injectors tick when i spin it manually. if anyone has any ideas please let me know!! thank you
R32RB20DET
Car: 1989 S13 Coupe
Hope you found out the problem. Have you tried swapping out to another ecu?
gandza
found the problem, it was a ground, but when i got it running i melted a coilpack?
