thanx for the welcome,kouki-gymkhana wrote:First, welcome to NICO since you only joined last night. I'm sure you will quickly come to realize that this forum is one of the best resources on the web for your proposed RB swap. Second, a simple search using the "search" button for the issues you've raised will likely answer all of your questions. It has been my experience that the members of this forum are very helpful but it might be more courteous to do a bit more research on your own first before firing away with your questions.
Once again, welcome! -kouki
thanx for that advice, ill be sure to use that when i get the clip.420_240 wrote:i'm going off of my car (s14)... not sure about s13...but i'll try to help...-lower harness use the two pos/ battery plugs that hook into a red plug-in... use a small loop (black ground) ground to alternator case... use red covered loop to alternator... ground big ground to block.... black covered loop to starter... there will be a prong that is protruding from your starter, if you still have your KA take the female spade and wire from the KA starter... connect the wire to the rb prong... plug in spade plugs.... that should be it to get it running... as far as speedo and reverse lights go, i'm not that far yet so you'll have to get some more advice from the nico elders... good luck man
No thats the upper harness in the pic. the lower would be to the left and going down along the frame and to the fuse box.Nismo240SX90 wrote:well i cant sleep, cause im pretty excited. i go pick my 240 up around 11am.
i had a question...
from the last pic i posted the wire harness that goes around the firewall is that part of the motor harness?
anyway after i clean up the car later on today ill post some pics..
ok, im pretty sure i have that then i have alot of harness that was layed on top of the drivers side and also i have the fuse box with + - leads that go to the battery along with the starter. ill take some pics tomorrow after i clean the engine bay, and you can maybe varify it more.Yellow4g63 wrote:
yea im pretty sure bro it had drive axles going to the front wheels im going there tomorrow to get a price on the "silver top" ill bring my digi and snap some pics.240DRFT wrote:hey ibzbro, its nice to see another person from washington...
nismo240, are you sure its a rb20 with awd? never heard of that...check out the stickies they have good info on installing the rb
Looks like you are good to go... this is what you keep.Nismo240SX90 wrote:here are those pics of the harness it has many connections would this be the whole harness?
