rb20det swap into '82 720
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
H3SSL3Y86
Car: 1983 Datsun 720
1986 Nissan 720
i already have the motor/transmission/harness/ecu and everything for the rb20det. im just looking for any help or advice on what its gonna take to fit this monster in my little 720 :ohno:
i know im getting into a huge project that will entail a LOT of work and money but im gonna make this happen, anything that will help will be much appreciated. thanks, ill be posting pics :dblthumb:
vbratsun720
Car: 1984 Datsun 720 king cab
I've been thinking of doing the same swap, Hope everything goes well and good luck on your build :dblthumb:
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
The engine is a little long for the engine bay. Even if the radiator is placed outside the radiator panel, you will have to cut the firewall and refit ot around the engine. The gear lever will also be further back in the cab so the opening in the floor has to be lengthened. its a great engine with lots of power. We had one which we use to drag race. This engine will also affect the dashboard.
H3SSL3Y86
1986 Nissan 720
finally got the old motor pulled. did you have any issues with the oil pan, were you able to use the stock pan or did you have to get a custom one made? we are going to start test fitting/cutting fire wall and stuff next week, i just noticed that may be a problem so i wanted to know if that was a problem for your build
H3SSL3Y86
1986 Nissan 720
flinterman2000 wrote:The engine is a little long for the engine bay. Even if the radiator is placed outside the radiator panel, you will have to cut the firewall and refit ot around the engine. The gear lever will also be further back in the cab so the opening in the floor has to be lengthened. its a great engine with lots of power. We had one which we use to drag race. This engine will also affect the dashboard.
hey man, I was just wondering what other issues you ran into on your build. we are about to start cutting firewall and getting into some fabricating and stuff. did you have to move the gas pedal or anything else? do you have pics of your build? do you have a thread on Nico Club about your build? I'm just trying to prepare as much as I can before getting into the real nitty gritty. thanks man
Return to “Datsun 720”
