RB20det swap / ?HELP?
POOPmouth
Car: The Devils pimp ride
hello name is daniel- i got a 91 240sx coupe- it has a swaped rb20det motor everything went fine with the swap- as for the last thing that i need is the wiring ?which i got that wiring info from carl H - thanksi just have a few questions - any help will be greatthere is a plug before th Y on the rb hanress is that used-plus on the info carl H gives- now all the rest of the wires that are there- they are not being used- of have no purpuse ? 2 question- O2 sensor wires - could somebody just tell me the color of the wires so i could extend them to ther place-? also on the instructions it says connect the KA-black/pink wire to the RB-black/pink but as i took all the wrap back all the way to the Y i see no black/pink on the RB harness - ?
Modified by POOPmouth at 4:14 PM 2/17/2006
POOPmouth
POOPmouth wrote:hello name is daniel- i got a 91 240sx coupe- it has a swaped rb20det motor everything went fine with the swap- as for the last thing that i need is the wiring ?which i got that wiring info from carl H - thanksi just have a few questions - any help will be greatthere is a plug before th Y on the rb hanress is that used-plus on the info carl H gives- now all the rest of the wires that are there- they are not being used- of have no purpuse ? 2 question- O2 sensor wires - could somebody just tell me the color of the wires so i could extend them to ther place-? also on the instructions it says connect the KA-black/pink wire to the RB-black/pink but as i took all the wrap back all the way to the Y i see no black/pink on the RB harness - ?
to view pictures go to my photo album to see what im talk about.http://pg.photos.yahoo.com/ph/...hotos
armysweitzer
Car: RB20DET S13
i dont have that plug hooked up the car runs fine, do i know what it is...No
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
im not using it either.
Try looking at this:http://s92978298.onlinehome.us/RB/gtr_plugs.pdf
if its not in there, chances are it isnt that important.
POOPmouth
thanks-couldnt really go into it tonight - so tomorrowill post after i itry a few thingsthanks
POOPmouth
koolwill check out-iwll try tomorrow will keep u posted on how things work-
BoostFab
Car: S13cp, S13fb, S14z
POOPmouth wrote:hello name is daniel? 2 question- O2 sensor wires - could somebody just tell me the color of the wires so i could extend them to ther place-? also on the instructions it says connect the KA-black/pink wire to the RB-black/pink but as i took all the wrap back all the way to the Y i see no black/pink on the RB harness - ?
do you already have the O2 plug on the RB harness? just cut it and extend them.
the black/pink wire is on RB-harness' white plug next to the Green relays near RB ECU. run a wire from there to the engine bay brown plug by the battery
nukeone
For the RB, NO WIRES need to be extended! If you separate the harness a little, you can get enough extension for both the MAF and O2 sensors (rotate O2 sensor bracket). Besides, both use shielded wire; cutting and splicing shielded wire can easily induce signal noise.
POOPmouth
the problem with the o2 is that it was never hooked up-im in process of looking for the wires so i can extend it - thanks for the help will keep posted
POOPmouth
OK this is what iv done so far sence the info givin to me-1ka b/r to rb b/r= found that2ka red - rb white black= found3=? says black/pink to rb-black/pink- found the wire running from the ecu plug-? is i can run it from there?4=ka b/y to rb b/w= found5-ka white red-found in the bundle of wires-? didnt find in rb harness wire uti i got to the ecu- notice that it splits off to the left of Y in in the harness going to motor= ? is can i also just run the wirie frm the ecu part to that wire on the KA-6-FB whitewire- ? that s the upper white wire running to the ignition switch-7-alit.white/blue ? location plz as i looked on my alternator it doesnt have the w/b wire- and that connect to the V-thick wire- ? what is the V stand for ?as for the MAF i located it and will bring closer to the Y- as for the o2 sensor wires- im having a hard time locating them- didnt have a plug or nothing -iv purchased a o2 from a 300zx T to but on there = but like i said can not find the three wires nor i dont know what color they areas in the pictures iv posted - i havethree brown wires that went all the way to the front- could those be it thanks again for the HELP
POOPmouth
Sweet one ? has been answeredo2 sensor - foundwhich wire is witch - or how should i hook it up2 browns one clear
POOPmouth
AWSOME - all wires have been hooked up -just alittle more work and she will be able to startthanks again for all the help_im dam sure its right so i guess i have to waiit tell everything is readywill keep u postedif i come up to more ?s thanks again people
POOPmouth
intercooler left to installbattery dead so couldnt test tomorrow is the BIG day will keep posted thanks again for the help
POOPmouth
thanks for ur info nico peepsas for the carita a gargeworksltd.comdam good - place - i know a few of them and they know there stuff so im pretty happy with these poeple working on my car-pretty much just letting the wiring get done by them - and intercooler- should be done in a WEEKthanks again=-pluz if anybody has a powersteering pump from ar32 basemodle with no hicas on itlet me know have cash in hand thanks agian people
