frosted flakes wrote:Yes this has 6 bolts to the flange. Im not sure if its cast iron or cast steel but yes there is a special way to weld it. Its gotta cool down VERY slowly or else it will crack. You need a sand bath for this. I just took mine to a welding shop i guess they knew how to handle this kind of material. It would be optimal to create a single piece pipe that goes from the turbo dump pipe to the catback. This is probably the fastest way for exhaust gasses to flow out. This is probably what i will do next since right now mine is just hooked up to my stock exhaust system (it is sooo quiet all i can hear is the TURBO and BOV)
