RB20det suspected Coil Pack problem
Drakelee
Car: 1992 Nissan 240sx RB20det
1986 Mazda RX7:for sale
1997 Ford Ranger:PitTruck<3
Hello all,
New to the RB world, I have a problem. The motor seems to be running threw coil packs, on my 3rd set of used ones. Runs perfect for a few weeks or months on a set and then starts to break up at high boost.
My question is, could this be because of the used coil packs I'v been getting or another possible problem? I would not mind investing in a new set of Splitfires as long as I know its not going to just happen to those as well. Just don’t want to spend nearly $500 on them and not solve the problem or worse have them ruined in the process.
Thanks
Cjmartz2k
Car: Hunting for a '89 GTR now
There are plenty of threads on NICO, skylinesaustralia, and all over the net about how to clean up and fix failing coil packs. Give that a shot before you even attempt spending money on splitfires.
StricNyne
how u know they r bad, did u check resistance ? are you perhaps blowing out spark ? how much is high boost ? maybe you need an ign upgrade (hks dli) or okada plasma booster, maybe even the new 5zigen econ. what plugs r u running ? (bkr7e) i am going to be a guinea pig for the pulstar plugs, and dyno with them, dyno with bkr7e, and dyno with hks dli in a couple weeks ! i let u know how it goes
Cjmartz2k
Now that I reread that, what do your plugs look like?
Broadfield
Car: 1992 240sx
Hey Drake, you sent me a PM about a cluster, but I can't send you a PM back because you need to change your PM settings to allow PM's from other users. You also have your email address hidden.
Carry on!
Toby
Drakelee
Broadfield wrote:Hey Drake, you sent me a PM about a cluster, but I can't send you a PM back because you need to change your PM settings to allow PM's from other users. You also have your email address hidden.
Carry on!
Toby
Sorry about that, re sent a PM and changed my settings!
StricNyne
i just painted mine with liquid tape, i did 3 coats, mine worked good i was just having some spare time
