Rb20det Success!!!
McAdam
Car: I like cars and my motorcycle. boats are fun too
well, I put a wire directly from the back/yellow wire on the ignition switch to the starter selinoid and she fires right up!! I suspect some sort of wire failure in the chassis harness because the black/yellow wire I clipped right after the plug on the chassis harness has a direct connect to the RB black/white starter wire.
I followed RubHamuSan's directions for eliminating the rear output on the HICAS pump. only thing I did differently was I put QuickSteel putty in the banjo bolt hole instead of welding it up. I threaded the bolt in to the hole a bit to make sure putty was squished into all the threads.
I even spliced all the transmission plugs onto the KA lower harness so it all plugs into the stock locations. and I also plugged in the KA oil pressure switch plug tothe correct prong on the RB oil sender unit so the oil light goes off after it gets enough pressure! sweeet deal.
only thing left to do now is bend the PS lines and fill the radiator and transmission. Anyone know how much oil the transmission holds?? I am assuming 80w90, correct? thanks!
McAdam
-HyJynX-
Car: CArs...cars..
Hey this is the swap done with the KA alternator right? because im ganna be doin the same swap in the next koming weeks and ganna be using the KA altern.
JonPowell
Car: Cars, Music, My family
Fill the trans until it starts to come out of the fill hole, thats all
McAdam
actually I used the RB alternator, it was already on the motor. but the KA and RB plugs are the same. so if the KA alternator bolts on to the RB motor, you should be all good in the hood.
as far as teh transmission, I filled it thru the gear shift hole. what can I say, I am lazy. I put 3 qts in, so that should be good. we drove it around the block a few times, very nice. I am leaning towards the RB20 for my 90 hatch.
McAdam
-HyJynX-
Car: CArs...cars..
Well im ganna try out the KA alternator to see how it works...i hope it works out well.
SHIFT_Lock
Car: kouki s14
2.5 for the transmission...3 works tho.
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
THE KA SHOULD BOLT UP PRETTY CLOSE CAUSE I HAVE PERSONALLY PUT ONE ON MINE TO SEE, IF I REMEMBER RIGHT ITS THE PULLEY ADJUSTER THAT IS ALITTLE OFF BUT MANAGEABLE.
SHIFT_Lock
Car: kouki s14
why would you want a ka alt for?
-HyJynX-
Car: CArs...cars..
because my RB20 ALter. is messed up and in non working condition from wut i heard. So im planning to use the KA alternator.
