rb20det stock bov question
bigfootap
Car: 1991 240sx coupe
I'm trying to get my rb20 s13 running correctly because it has a high idle, around 2000. I have a feeling that since my stock blow off valve isn't recirculated that it is causing this high idle. And I'm not sure if the little vacuum port under the throttle body being open at the moment is causing it as well. I just replaced my water pump and all timing components and just recently got it running. Now it would be nice to figure out the idle thing so I can drive this beast!
TheRBguy
Car: S13 240sx Rb25det swapped
If you have your stock recirc valve vented to the atmosphere that is your issue, a friend of mine did this and his car ran fine just wouldnt idle properly.
Krazykouki
bigfootap wrote:I'm trying to get my rb20 s13 running correctly because it has a high idle, around 2000. I have a feeling that since my stock blow off valve isn't recirculated that it is causing this high idle. And I'm not sure if the little vacuum port under the throttle body being open at the moment is causing it as well. I just replaced my water pump and all timing components and just recently got it running. Now it would be nice to figure out the idle thing so I can drive this beast!
If you are aware of vacuum leaks, fix those first. That open port on the throttle body will cause it to idle at 2k rpm. Fix that and let us know what the result is.
bigfootap
Alright, I read that the port under the throttle body went to the charcoal canister which means i can just block it off right?
Gabes13
Car: rb20det s13
Yes, just capped it off. And if you're not recirculating your bov, make sure you cap off the recirculated tube so no unmetered air is used.
bigfootap
Do you mean the tube coming off the bov?
Gabes13
Car: rb20det s13
Yeah, the one that leads from the bov to the turbo; cap it off.
Carl H
stock bpv is designed to be recirc'ed, if you do not recirc it the car will never run right.
they are designed to leak boost pressure and if you keep it open it will be laggy and down on power.
bigfootap
so is it ok to cap it off for the time being since i dont have a bung on my intake pipe.
Carl H
sure if you like compressor surge and want to see your ceramic compressor wheel shatter.
bigfootap
well i dont really want that to happen..
bigfootap
Will a Greddy type S or RS line up to the stock bov location?
Carl H
it will...well, enough to drill and tap and have a reasonable seal.
bigfootap
alright thanks carl. I'll update this when i get some time to work on the car
TheRBguy
Turbo xs makes an adapter to bolt an RFL right onto the stock location.
bigfootap
really? do you have a link to someone who carries it?
TheRBguy
Carl H
rfl sucks, they leak and are obnoxiously loud.
personally i would just rock the stock diverter, properly prepped they will hold 30psi.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
If you need a stock / GReddy style flange, LMK.
I have one that was made of CNC'd alumnium. All it will cost you is shipping.
bigfootap
Do you have a picture lonestar? how much shipped to 28115?
RustspecS13
Car: '74 260z and '88 300zx turbo
Carl H wrote:sure if you like compressor surge and want to see your ceramic compressor wheel shatter.
I thought we established that the compressor wheels were metal, and all the exhaust wheels were ceramic on RB's, except the neos which had a nylon compressor?
My friend is building a KA-T setup and he says hes not running a BOV because a lot of drifters (like PBM guys etc etc) don't run any and they are fine.
The CA18DET didn't have a BOV, and 90% of their turbos are blown. I think my friends had 1/4in of shaft play, and the compressor and turbine were all chewed up.
Yeah, you need a BOV.
~Alex
TheRBguy
Unless you are running a heavy duty diesel turbo then you can just let it surge and it wont hurt it.
