McAdam »
https://forums.nicoclub.com/mcadam-u5096.html
Wed Jul 23, 2003 4:07 pm
thanks for the words of advice, I'll check all this stuff. as far as wiring, here is what I did......
I used the KA harness for all the starter and alternator stuff. I mean, the positive cable just runs between the positive terminal and the starter, so thats that, no matter what harness you use. And none of the RB fuse block plugs are used, so I saw no reason to use that harness.
I'll check the starter switch. It acts like the clutch safety switch is not engaged. when you turn the key, one of the relays in the relay box by the drivers side headlight clicks, but thats about it. I tried pushing the switch by hand and starting, but no go. time to break out the multi meter!
on a side note, it does run, and it runs quite nice. just have to plug a few vaacum holes and it should be all good. Damn, I miss my 280zx, straight sixes are teh bomb!
McAdam
edit: if the starter selinoid was going out, would that have an effect? about hallf the time when I jump it with the screwdriver, it will just spin, no selinoid action, it doesnt engage. maybe I'll get the stock KA starter and see if it works.....
