b00stinbmx »
https://forums.nicoclub.com/b00stinbmx-u122913.html
Sun Jun 07, 2009 4:07 pm
well i got the swap all done and wiring all set. i turn the key and starter clicks. battery is at 12 volts and i also had a charger on it. i jumpered the relay still same thing it just clicks dosen;t want to turn the motor over.
so i pulled the starter off the transmission with wires still hooked up and hit the key, it clicks for a second while the gear extends then it spins no problem. i then took it completely off and hooked it up to the charger and it spun no problem. so im wondering if the starter is just shot and it dosen;t have enough power anymore to turn the motor over. it spins reall fast and def seems to work fine but like i said all im getting is clicking when i turn the key when its in with a full charged battery. someone please help i want to try to get this thing running and thats the only thing stopping me right now!!!
with that in mind if the starter is junk is there any RB crossreferences for USDM cars so i can pick one up? thanks for any help guys!
