alright so the ignition wire and the ground?? should be on the starter terminal?? this is my starter (providing the pic worked on here) and i still hav to look for that wire but this should be my ground.... i think but im showin u guys so if it isnt please let me know.. i think thats the only other questions i have at the moment .. i do appreciate the infos13_240_rb20 wrote:You're probably looking for a black/yellow wire with a round terminal at the end of it, cuz it bolts on. You should also find a female slide on connection for the ground.
The black/yellow (??) should come through the firewall and probably goes to a chassis harness plug that then connects to the lower harness and on to the starter. The black/yellow is about 10gauge wire.
To be sure about the color of the wire you are looking for, you can take the covers off of your steering column and then use a test light on the wires on the back of your ignition switch. There is only ONE that will light up your test light when the key is turned all the way to the "start" position. This wire should be connected to the starter at the other end.
Again, I am guess that wire is black/yellow?? I can't guarantee that without going outside and looking at mine, but now you should be able to find the wire at the ignition and trace it back to the engine bay somewhere. I am guessing that your black/yellow stops at the chassis harness, and you probably are missing atleast part of your lower harness??? Oh yeah, iirc, doing an rbswap you can expect a loose ground connection unless you replace the slide-on ground terminal to the starter. (iirc??) Anyways, if it ever stops starting or the starter just clicks, then try wiggling your starter ground wire....could save you some headaches in the future if you remember that??
I jacked up my wiring when I did my swap and had to diagnose/rewire my "no start".
--TJ
Modified by s13_240_rb20 at 6:24 AM 11/26/2009
However, if he is missing the spade connector plug and he has to wire it himself, where should that wire be wired to?? (what signal does it get from where)....gawdzilla wrote:^correct.
that large gauge wire in the picture is a constant 12v. the spade connector is the trigger for the solenoid. there is a short wire that comes with the starter that connects the starter to the solenoid directly and grounds the solenoid. the starter is grounded through the block. some of the information posted further above is wrong.
