Rb20det stall out problem
importredneck
Car: 1991 240sx hatch rb20det
Hi i just reinstalled my rb20det new turbo new piping new tial 50mm BOV (11 pound spring) everything runs good but at lights or even around speed bumps the thing stalls out constantly. all vaccum lines are sealed and clamps on piping were c hecked alittle help please thankx. Right now the boost is at 7 psi
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
importredneck wrote:Hi i just reinstalled my rb20det new turbo new piping new tial 50mm BOV (11 pound spring) everything runs good but at lights or even around speed bumps the thing stalls out constantly. all vaccum lines are sealed and clamps on piping were c hecked alittle help please thankx. Right now the boost is at 7 psi
Thats the problem right there, Some cars seem to be more sensitive than others when it comes to venting to atmosphere. Get a PFC or standalone and you won't have that problem anymore. Or you could just put the stock back on an reroute it back into the take like it is stock.
Sil240
Car: Nissan S13 "The One Cam Wonder"
Hey do you think that maybe its a loose wire.Cause when your stopping everythings abruptly moving towards the front and at a speed bump everything is getting shaken up.
But while driving its smoothly moving.
How far are you from Broward??Seems like there's a couple of RB's aroung SFL huh.
importredneck
THe custom piping prevents me from going back to stock, my friend is telling me that i might less'n the effect of the different set up by putting the MAf between the BOV and the Throttle body that way it gets a more acurrate reading of the air in the piping...all the wires are tight and i'm in homestead bout 40 mins from broward
Joe
Sil240 wrote:Hey do you think that maybe its a loose wire.Cause when your stopping everythings abruptly moving towards the front and at a speed bump everything is getting shaken up.
what?
everything that controls the car is bolted down, none of it moves with you hit the brakes.
importredneck wrote:THe custom piping prevents me from going back to stock, my friend is telling me that i might less'n the effect of the different set up by putting the MAf between the BOV and the Throttle body that way it gets a more acurrate reading of the air in the piping...all the wires are tight and i'm in homestead bout 40 mins from broward
do *NOT* do a blow through MAF without retuning your car. moving the mass airflow sensor is not a game and can cause serious engine damage if done improperly.
you need to recirculate your BOV to eliminate this problem.
