rb20det Shifter I need Any.
Miata Master
Car: 240sx w/ rb25det SOON
I am going through a fiasco with my engine swap. The clip i bought came with nothing but the:
Rb25det engineRb20det 5 speedRb25det ECU & harness
This was a full clip i paid for. anyways The transmission did not come with a shifter or slave cyclinder.Can anyone help me please, a stock rb20det shifter or slave cyclinder would be fine. thanks. and what clutches can I Use thanks.
Miata Master
also If I have an rb20det trans on my Rb25det can I use a stock manual S13 driveshaft? If not I am not even going to install this.
Andrew85cm
Car: 89 240sx with RB20det
Yeah you can and its actually shorter too. I did not realize this when I did my RB20 swap so now I have a freakin truck style shifter using the RB shifter. Go with that s13 to the best of my knowledge I am pretty sure it fits considering you can use short shifters from RB, SRs, or KAs. Hope that helps.~ANDREW~
Slo_240sx
Car: Mean Green LS1 S13. Caged and Backhalfed.
I have stock rb shifter for you if you want it for 25 shipped. Do you need the whole plate or just the shifter?
Clutch for Rb20 and 25 are 300zx Non turbo models. Turn the flywheel when you replace the clutch or its gonna chatter like a SOB.
-Alex
Miata Master
Sold to the man who started the thread. I have the plate but If it is easier to install with plate still attached that would be great. I have no parts IE bushings clips nothing. I have the plate still but it hass a white plastic piece inside and nothing else so yes I would like the shifter.
Now to find a s13 5 speed driveshaft off to find a junk yard I guess.
BoostFab
Car: S13cp, S13fb, S14z
you can use the ka shifter and the drive shaft.
Miata Master
well i dont have a shifter or drive shaft so. I will go look for a drive shaft in some yards. but 25 for a shifter sounds fine to me.
is the rb25det transmission longer than an RB20det trans. ? manual of coarse.
