rb20det s14 crank no start STILL!
dacoldests14
Car: s14 with rb20det,pbm coils and links z32 front calipers
ok short story goes I get everything that has to do with fuel /spark and timing I have the car at my techs shop and we get spark but is very weak, so weak starting fluid doesn't help at all what would cause the spark to be this weak?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Bad grounds. Why don't you start with some more info? What harness? who did the harness? 2 green relays near ecu still in place? is it grounded from the motor to the body? yada yada yada?
dacoldests14
wiring specialties harness so grounds should b new confirmed spark with cas test, if a ignitor is on it's way out would it cause weak spark? did the j30 ignitor swap btw
Yellow4g63
Is it a stock swap? like stock injectors, maf and ecu? Make sure the fuel lines aren't reversed or it really won't start at all. Try and unplug the maf and coolant temp sensor and see if it starts.
Carl H
check your fuses.
talonp
I don't see this being a fuel issue if starting fluid does not help. I had this same problem on my sr and the timing was 180 off, it wouldn't backfire or anything just crank even with starting fluid. I was surprised how weak the spark was on my rb25 but it always ran fine. Are you comparing the "weak spark" with another rb motor you had? Or does it just look weak?
dacoldests14
yup all stock except fmic and tried unplugging maf still nuthin haven't tried coolant temp sensor yet, and all fuses are good and timing is perfect and spark looks weak very faint been waiting for awhile to get this running
Yellow4g63
Check your plugs too make sure they aren't fouled up. I'm not too sure about the J30 ignitor swap but if it's wired right shouldn't be a problem either.
Carl H
again check your fuses.
depending on how it was wired if the eng cont fuse is blown (7.5a) it will spark when you spin the cas but it will not spark when you crank it...and the spark with the spun cas will be VERY weak compared to a proper spark.
i have done this a few times now...
jesse0357
Car: 89 240sx rb20det swap
dacoldests14 wrote:wiring specialties harness so grounds should b new confirmed spark with cas test, if a ignitor is on it's way out would it cause weak spark? did the j30 ignitor swap btw
i had the same issue call them up theres a wire that you have to put in a pug, there really cool at wiring specialties
dacoldests14
Ok ill check again and I also have a j30 cas btw don't know if it makes a difference
jesse0357
the j30 shouldnt matter if its wired in correctly, i did the j30 swap too, thought it was the issue till i called wiring specialties and found out there harness is ment for 2-3 different set ups for the rb20. call them up and tell him your issue and he will help you out. like i said sounds exactly what my car was doing. it was just one wire pluged it in and fired right up!
