DriftingisLame »
https://forums.nicoclub.com/driftingislame-u25409.html
Wed Nov 14, 2007 12:13 pm
Get yourself a nice set of gauges, and do the necessary preventative maintenance. I lost a motor something as simple as an intake manifold gasket. My motor had high mileage (180k or so), and my area's of trouble were: overheating, broken coolant hoses, and coil packs. If you get yourself a water pump/timing belt/tensioner, and all new coolant hoses (all of them, I mean it), and an intake manifold gasket, and dont be stupid, you could see quite a few miles out of the rb20.
I recently tore apart another rb20 that I blew up, (totally my fault, I got too greedy with the power) and found the rod bearrings and rings to be in nearly new condition, the headgasket showed no signs of wear (275whp), 110k kilo's.
If you dont be lazy, your RB will last just like the 1jz.
PS: My heat problems started when I moved to phoenix AZ, and got worse until it hydrolocked.
