drivnovrdaedge »
https://forums.nicoclub.com/drivnovrdaedge-u64099.html
Tue May 01, 2007 7:22 pm
WELL HELLO GUYS
this is my first post on this site ...
i am located in washington state and recently obtained an rb20det for pretty cheap
i am in the process of rebuilding it since i was told that the engine has a blown head gasket (picked up from a shop in the area)
did a cylinder leak down test .. results:cylinder #1 - 25%cylinder #2 -30%cylinder #3 - 40% ahhcylinder #4 - 31%cylinder #5 - 27%cylinder #6 - 22%
so yeah .. it might just be warped .. noticed most of the gasket were pretty worn .. and the block is a bit rusted in the block .. you can see all the orange in the coolant channels ... also when i look in the cylinder through spark plug holes .. i can see it is pretty much VERy black and as well as the spark plugs being black .... was running rich i guess .. not very well taken care of engine being a 240 before i got a hold of it
i am going to be taking the head off tomorrow hopefully
waht i have purchased already:-nissan r32 (rb20det) engine gasket kit-water pump-thermostat-timing beltsome more stuff but i forgot ..
i have heard about the crank collar near the oil pump ? waht is that about? waht should i buy to eliminate the problem since i got the means and the engine apart!
anything i should upgrade?
waht should i look for? while i have it apart?anything in particular will show wear the most?waht else should i buy?waht should i invest in?
my budget is $700.00 total .. so yeah .. see waht im workin with
i dont have to pay for work to be done since i am doing everything myself. i am currently attending a local technical school . and we have ALOT of tools (many specialty tools) that i have access too
and i might have a discount at local machine shops .. but i dont know about that .. hopefully .. get the dech machined to make sure it is better
here are some pics
thanks muchMARCO
