Porschephile »
https://forums.nicoclub.com/porschephile-u9418.html
Tue Mar 09, 2004 1:31 am
Brad D on Hybridz.org sells the RB Z mounts for $100! Can't beat that. As far as a RB Datsun Z swap, the nice thing about the rb20 and rb25 is that, with the 200zr sump and Brad D's mounts (or 200zr mounts work, not ideal for handling), the engine bolts in and no further modification is required. Modifying the 200zr sump is only necessary on the Rb26. That's one of the reasons I seriously considered a rb20/25 because it's just too damn easy to get the drivetrain bolted in. The only thing custom you have to do is the transmission mount, but I've got that figured out and it really isn't hard. Just some minor cutting and welding on the existing Datsun transmission crossmember. Then get a custom driveshaft (you can use the front half of a z32 driveshaft) and your drivetrain is all taken care of. After that you just have to do intake/exhaust/coolant plumbing and wiring and you are about 99% done (still need aftermarket gauges and a few other things). It's not exactly as simple as a CA/SR s13 swap, however I'm surprised there aren't tons more people with RB Z's in the US considering how easily it can be done. Considering how cheap Rb20's are, you could swap one into a Z for under $5k, with mods, if you do everything yourself. I'd still like to build an rb20 240z in the future for a more casual daily driver than my current one will be.
