RB20DET Questions
FlyingSpudnik
Car: 1977 280Z
I guess I f*** up, I bought a 200ZR RB20DET that comes with NICS.
My name is Tommy and I am a senior in highschool, I decided to engine swap my car for my senior project. I ended up buying a 200ZR RB20. The only problem I have is that I cannot buy a pre-made harness. I bought this engine for $500 USD and paid a total of $1000 + Shipping. For now I need a few questions answered so I can hurry and finish my senior project.
Can I bolt a Silvertop ECCS Head to a Redtop NICS Block?
If the answer is yes to the Silvertop ECCS head on a Redtop NICS Block, can anyone send me comparison pictures of the Intake side and the exhaust side of both heads to make sure I am buying the correct one?
If the answer is no
Other than removing the butterfly valves and more boost, how can I add more HP to my engine?
Is there a write up for the butterfly valve removal or is it straight forward?
If ebay does not have an RB20 ECCS Head for sale, does any member on this page have one for sale? and can I buy it off of you for $350 USD?
Ken@PTUNING
Car: '92 Nissan 240sx KA-T
Yes, you can transfer the heads but it may be cheaper to simply get the right long block and sell the NICS motor.
Unless you're going for crazy boost pressures, do not remove the butterfly valves. They're meant to be a variable length intake runner system. You will lose a lot of your midrange torque doing so.
As for making more power, normal modding list applies. Exhaust work, intakes, and tuning will likely net you nice gains.
FlyingSpudnik
Car: 1977 280Z
Ken@PTUNING wrote:Yes, you can transfer the heads but it may be cheaper to simply get the right long block and sell the NICS motor.
Why would it be easier to just sell the current engine?
Ken@PTUNING
Consider not only the cost of the new cylinder head but also the associated items such as the headgasket, intake/exhaust gaskets, new headbolts/studs,any machine shop fees, etc.
FlyingSpudnik
Car: 1977 280Z
Ken@PTUNING wrote:Consider not only the cost of the new cylinder head but also the associated items such as the headgasket, intake/exhaust gaskets, new headbolts/studs,any machine shop fees, etc.
So I would have to get the head machined to the block and new headstuds/studs?
Thats an additional $400-500 just for those, and another head will be around $500 :/
Now for just putting mods onto the Redtop, no one makes an intake for the nics. So I will be forced to run the ugly oem intake.
Besides from the ulra-expensive turbo manifolds (Full-race, DOC, RawBrokerage) are there any affordable top mount manifolds?
Ken@PTUNING
Yup, and you now see that it adds up. Whenever you pull a cylinder head, it is in your best interest to take it to a machine shop and have them check the flatness and/or surface the head as either can cause a new headgasket to fail. Head bolts should never be reused as they are torque-to-yield (they stretch/deform to the specified preload). I would never advise anyone to crack open a motor unless they have to.
Good manifolds are expensive for a reason. You can try your luck with $100-$300 manifolds. Some get away fine for years with absolutely no problems. Some have warped flanges right out of the box. Some may crack or may not crack.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
I'm pretty sure you can bolt the silver top head on to the older block. I use to have a redtop block many moons ago.
Your best be would prob to do a mega squirt 2 ecu setup on that motor. It's cheap and will get the job done, It will be some good leg work but it can be done. If you don't have to pull the head I wouldn't unless your going to upgrade to a metal headgasket and ARP studs at the same time.
Yellow4g63
Also just rock the factory manifold. Here are some old pics of my SC61 turbo on the stock manifold. The manifold and turbo could have been shaved down and it would have cleared. You can also just add a external gate at the collector of the manifold and BAM ebay turbo here you come lol.
post689288.html#p689288
Carl H
would you be interested in parting with the valve covers and coil pack cover from the NICS motor?
Yellow4g63
Carl those are long gone lol. It's been atleast 4 years since I last saw them.
Carl H
Yellow4g63 wrote:Carl those are long gone lol. It's been atleast 4 years since I last saw them.
lol, no to the OP.
Yellow4g63
ahhh ok.
FlyingSpudnik
Car: 1977 280Z
Carl H wrote:would you be interested in parting with the valve covers and coil pack cover from the NICS motor?
Sorry man, can't do
FlyingSpudnik
Car: 1977 280Z
Does anyone know what this sticker means besides Impul? (https://en.wikipedia.org/wiki/Impul)
http://i.imgur.com/AAhHY9F.jpg
Googling Rev.Z Impul results in nothing
Yellow4g63
Prob the last place that worked on it.
