Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Fri Nov 28, 2003 2:37 pm
Ok, I've got a few questions. First of all, my engine wiring harness has two green relays wired inside the passenger side kick panel right by the ECU. These are in addition to what should be the ECCS relay. Could one be the ignition coil relay??? And what about the other one?
Also, my cluster has a gauge for front wheel torque from 0-50 ft-lbs., and does not have a boost gauge. This would almost certainly be an AWD cluster, right? But this clip does not have AWD. Did Venus switch the clusters?
TIA,Shane
