themadscientist »
https://forums.nicoclub.com/themadscientist-u2806.html
Mon Jan 12, 2004 12:46 pm
The RB uses bolts not studs and i have never seen a stud kit for it. I'm sure somewher somebody makes one but it's not really needed the stock bolts are fine. If I was in the states looking at a frontcut with an RB in it to go into my 240 I would do this;
Pull the oil pan and valve covers, look for sludge or evidence of excessive wear. Crusty and or goopy sludge is a "do not pass go,do not collect $200" affair, the motor needs a complete overhaul. If you have a clean head and some junk in the pan you should be ok, clean the pan and bolt it back on with new sealant(they are siliconed on from the factory). The valve cover gaskets and rear halfmoon seals should be replaced.
Replace the water pump, it needs it just do it now or you will hate yourself inevitably. replace the timing belt, tensioner and idler. You will be tempted to reuse the pulleys, don't, a locked up bearing will really ruin your day so just replace them. If you want to be nifty and you know how you could get some adjustable cam gears and degree in the cams but that depends greatly on how anal you want to be. It's not needed but it's a good thing.
Replace the front and rear main seals. They need it, it's stupid when they leak and it will piss you off so replace them now. Replace the pilot bushing in the rear of the crank. They rarely go bad but cmon they are like $5.00 and the damage to you transmission bearings if it goes south makes it worth the 15 minutes to pop a new one in there.
Now, head gasket. If you are going to run around with a stock turbo and plan on doing a rebuild before bolting on anything bigger leave the OE gasket in. Now if you got a hot little T3/T4 screw ready to go might as well step up to a 1.2mm stopper type head gasket from HKS or Greddy or Tomei. Bead types are cheaper but they are only marginally better than stock. If it's worth taking the time to do it it's worth doing right and with a top rank gasket you will likely punch a hole in the piston before you pop a head gasket. Now if you do the gasket use a machinist's straightedge and check the head and the block for straightness, RB20s run notiously hot and the head might have been warped in it's life. If you have to deck either realize you will be raising the compression ratio so be aware you might have to go thicker on the gasket to keep the ratio you want.If you do the gasket it will give you the opportunity to look at the pistontops and combustion chambers, if they are carboned up clean them and if you are so inclined you can have a laundry list of nifty work done to it but to drop $1000 in headwork and not overhaul the bottom end would be stupid, use your own judgement on that.As I mentioned the 20s run hot so stepping up to a quality radiator, at least a two core is a must. Once you have the engine in the car you should do a compression check and make sure the cylinders are reading even across the motor and not amazing low.A series of oil changes to gently flush the motor out are next. I use a decent dino oil, a little thin so it can get in there and carry the crud out into the filter. I am against motor flush as it is too agressive and you run the risk of breaking loose huge chunks of crap that could plug an important oil passage and make you sad.After it's all cleaned out you can start using good quality oil and begin your intervals as normal.
