rb20det_pwr wrote:After bleeding the slave (the one that bolts onto the transmission), find the bleeder valve on the "clutch master" and bleed that too.
Was this car auto before?
ive never seen a bleeder on a master cylinder you usually have to do a procedure called bench bleeding with the master out of the car.
just do a gravity bleed.
open the slave cylinder bleeder, take the cap off the master cylinder, let the fluid drip untill its clear with no air bubbles (make take several minutes)
then adjust your clutch pedal.
