rb20det problem
ash32
hay there iv got a rb20det factory coupe , its got a problem once its warmed up it ildes up and down between 1000rpm and nearly stalls done ecu check come back 55 all fine any help be great
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Check for vacuum leaks. build a leak tester and track them down.
ash32
done the leak down test found a few leaks and fixed them, still got the bouncing idle anything else i could try?
ash32
anyone
Yellow4g63
Try cleaning the iacv. Maybe its got some crap or dead insect in it
Carl H
sounds like the idle switch isnt engaged.
Black_label_240sx
Car: 240sx s13 with rb20det swap
so, checked out the switch, and the tps for good measure
no dice, nows its running ritch as hell, like 10 afr at idle.
drives decent, still a 10 afr.
and does the retarded timing at cold start.
Could a bent CAS wheel be causing all of this? Imean its tweaked pretty good..
Granted I don't have an after market FPS to go with 255 walburo, wonder if that blew the stock pressure regualtor?
ash32
on cold start up it runs fine once its warmed up then it start runing up and down, runs fine other than this boost great , just on idle it revs up to about 1000 for a few seconds then drops nearly dies then back up to 1000
