The settings on your safc are wrong it should be 2 in 4 out, and if you have stock injectors the adjustment sould stay at zero. I'm in jax too send me an email if you wanna get together.. not many rb's here in jax that I don't know of or havent done some [email protected]mikalkouki wrote:i can't find out what the problem is with my rb20det s14!!!! It starts and idles just fine, but when you try to give it and throttle it stumbles really bad. If you very lightly apply throttle it will slowly reach higher rpm's arounk 6k, but stumbles on and off while getting there. Any sudden throttle bogs the engine almost to the point of shutting off. I've tested the maf on another vehicle works great. Tested the ecu on another vehicle... works great. Same goes for the ignitor chip and CAS. Fuel pump is spraying plenty of fuel when plugs are removed.... What could possibly be the problem????
I do have a z32 maf with an safc tuned to -27 across the board and the sensor no. is set at 2in 6out...... but like i said, idles awesome. problems occur above 2k
yeah it sounds like a boost leak.. replied to your emailmikalkouki wrote:had to be something set up wrong in the afc maybe the dec. air settings..... initialized all settings and runs a helluva lot better, however it still sputters a bit under acceleration and backfires after throttle is released. also when it's in drive there is almost no power! push the throttle to the floor and it won't even spin the tires in grass???
yeah, unfortunately I did the same thing ( Iridiums @ .70) and the problem still persists....... I just got a wideband o2 sensor and I'm about to be fine tuning it to make sure of the afr, but I really don't know why it would be running so richVkoslak wrote:I just fixed this on my car. I had the gap set wrong and I was using cheap arsed plugs.
Now I'm using some iridiums and I used a measuring caliper to get the right gap.
I had already replaced igniter and some coil packs. Guess that means I got more extra parts now though. lol
actually i was wondering of not shielding the maf wires for that small section would cause this problem... how did you shield yours? connect the speaker wire to the shield wire and run it around the wire foil the speaker wire and electric tape it up?Vkoslak wrote:You know, I had a z32 maf I got off ebay that would work fine in my 300zx, but would cause my rb to run really rich. So I took the one from my 300zx and ran it on the rb and it worked fine. The stickers were slightly different, but all the numbers were the same. If its possible, find someone with a 300zx and have them let you try their maf.
When you rewired your maf, did you shield it and ground it at one end? I did some ghetto shielding with aluminum foil, speaker wire, and electrical tape.
