RB20DET - Problem Fuel Injectors do not fire!!!!!!!Cranks and cranks and that is all.It does not burp, fart or spit.
Has sparkCAS works at least with sparkFuel Pressure is presentFuel lines are correctExhaust cam key has broken off inside of the CAS.Tried to get it out and glue it, but it is stuck inside.Lined up the CAS according to the broken area on the cam.But car doesn't even give me a fart, flame or a burp.
Green Relays click when I turn the key and thats it.Fuel pump turns on with or without Green relays installed.Does anyone else's car work the same way??
I have power at the injector leads all the time. (Batt voltage)But have no grounding from the ECU.Have tried jumping the harness, (taking wires from right out of the ECU straight to the injectors.
I've searched and searched couldn't find the thread I'm looking for.I did find a perfect thread with the same exact problem 2-3 weeks ago, but yet I cannot now.
If you have any information please let me know
Brian
[email protected]
