Id even like to find a .020 oversize if they make them.
If they are not available is there any piston out there out of anything that can fit.
I read a bit of chatter that a vg20de piston ring fits but I can find rings or pistons for that engine either.
THIS IS A LONG SHOT BUT.....
A 1.8 liter Honda has a 81mm bore possibly those could work. I believe the piston pin offset would be the biggest problem. Next would be ring lands up too high being non turbo. Then the height would probly be off significantly.
I bored my last engine to 79mm and it has absolutely zero overheating problems so assuming there might be enough meat left.
I do recall my machine shop saying that in between cylinders would get pretty close any bigger.
Maybe im way in left field on that idea.....
I know supertech has .40 over pistons but id like to find an option cheaper than 800$ (plus machine work)......
