rb20det p/s and iac question
slidewaysrb20
Car: 91 240sx w/ Rb20det swap
i recently bought s13 with and rb20det swap. the car doesnt have p/s and i would like to put it back in as its my dd. i was wondering if the r33 p/s pump will work on the r32 with out any modifications? and also if there are any other p/s pumps that are interchangeable from other cars and what i would have to get for p/s lines so the pump will work with the stock rack in the s13. i was also wondering if any iac was interchangeable from any other car as well and if not where i could possibly find an oem replacement? i'm new to the 240 scene so i'd really appreciate any help or info i can get. thank you
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
You need the non Hicus power steering bracked along with the pump. The Rb20 uses a Hicus pump.
slidewaysrb20
Ok,awesome. thank u so much you saved me from buying the wrong pump and wasting $180
locoluna825
Car: 90 240sx coupe
You can also use a dual cam s13 pump. If you already have the rb powersteering bracket and adjuster. Very Very little modification is needed to make it work. Did mine works great. glad i didnt spend 100+ bucks a on a used rb power steering pump that might eventually go out or leak, now I can buy powersteering pumps for nothing if I ever need one again. You want to get a hold of a dual cam power steering system, if you dont already have one. Both lines; hardlines and the resevor. they are a little bit of a pain in the a** to install when the motor is already in there.
